Attempting to remove water pump.
Needing to remove power steering bracket from WP.
Appears to have extremely large Hex type set screw or bolt that holds pulley on. I have tried securing pulley and using breaker bar to loosen this bolt in both directions. My question is: How does this pulley come off? If I use a puller on it, how would I ever press it back on? It would seem that this center bolt should come off and then the pulley slides off, then the bracket comes off, and then I can remove the WP. I am at a stand still until I know for sure the proper removal method.
The pulley is plastic, so I can not use heat on it.
Please advise.[img:2ff4e5a169]http://www.2carpros.com/forum/automotive_pictures/94859_power_steering_pulley_1.jpg[/img:2ff4e5a169]
Oct 18, 2009 at 9:32 AM
