1997 Mercury Cougar pcm online
1997 MERCURY COUGAR
93,000 MILES • V8 • 2WD • AUTOMATIC
ABENDER
  • 4 POSTS
can you purchase a pcm online and then have it reprogramed for your car, the car is only worth about 3k and they want over 750 to fix it, i have to turn my key half way and let the cooling fan shut off before starting the car, the dealership hooked it up to diagnostic for $75 and they said they can not tell anything until the pcm is replaced, they think replacing it will fix my problem, but they would not print me out a copy of the diagnostics that they did
Oct 6, 2009 at 11:53 AM
SERVICE WRITER
  • 9,123 POSTS
The information I have says it can be programmed out of the vehicle. If you call a parts store or contact an online company, they can verify it before you order it. They will probably want the old one.
Oct 6, 2009 at 2:56 PM
ABENDER
  • 4 POSTS
[quote:578c01aca8="Service Writer"]The information I have says it can be programmed out of the vehicle. If you call a parts store or contact an online company, they can verify it before you order it. They will probably want the old one.[/quote:578c01aca8]
thanks
Oct 6, 2009 at 3:30 PM
