I removed the dash to replace the heater core. After installing the dash and hooking up the all wiring connectors I have several electrical issues. The head lights, tail lights, signal lights, parking lights, interior lights don't come on. If I pull the multi function lever (HI/LO beam switch) towards me the brights will come on until I release the switch. The clock doesn't light, the volt meter doesn't work nor does the water temperature gauge. The wipers do work but won't auto park when you turn off the switch. The radio works and the heater and A/C does work. The reverse lights work. The car does run and drive but I don't believe that the cooling fan comes on. All fuses are good and I do have power to the hot side of the fuses in the fuse block (checked with a Fluke meter) Any ideas as to what I'm missing? All the grounds seem to be connected. The ones by the battery and the one in the drivers kick panel. I must have missed something but I sure can't see what. I do have the Factory Service Manual and the Factory Electracial Vacuum Manual but I still don't see what I'm missing.
Feb 20, 2010 at 3:58 PM
