1996 Mercury Cougar hard starting
1996 MERCURY COUGAR
87,000 MILES • V8 • 2WD • AUTOMATIC
ALEX SYMONDS
this problem just started. hard starting,but not always. had a tune up w/in past 18 months. car runs great except for hard starting at times. thanks for any help..alex
Dec 12, 2007 at 7:54 AM
2CARPRO JACK
  • 11,533 POSTS
Hard starting as in excessive cranking, or it sounds like it is having a hard time cranking? Is or has the check engine light ever been on?
Dec 12, 2007 at 1:52 PM
ALEX SYMONDS
Hi JACK, just got in from work.Thanks for your reply!The car does crank a little excessive, but not like its having a hard time. And yes, the check engine was on for a little while, but went out after I replaced a bad battery. The car runs great a lot of power no hesitation, just cranks a little excessive; never did it before. It would start RIGHT UP! NO PROBLEMS. THANK YOU VERY MUCH for your help! ALEX.
Dec 12, 2007 at 6:37 PM
2CARPRO JACK
  • 11,533 POSTS
When was the last tune up? Fuel filter? Its due. Might also have the fuel pressure checked to be sure it isnt bleeding down due to a weak pump, injector or regulator
Dec 13, 2007 at 7:08 AM
