1994 Mercury Cougar repair/diagnose
1994 MERCURY COUGAR
16,000 MILES • V8 • 2WD • AUTOMATIC
JOHNNIEB33
my cougar is using a excessive amount of gas and i can smell a raw gas smell when driving, it is a bit sluggish and i need to travel 800 miles to get home and i sure wont make it in this condition can you help ? i was told the egr valve and/or mass air flow sensor?
Apr 30, 2010 at 8:21 AM
MATHIASO
  • 1,209 POSTS
The evaporative emission control system that consists of the carbon canister, the CANP purge control solenoid(s), purge valve(s), the fuel tank vapor hose, and the fuel vapor return line must be checked because of raw fuel smell.The canister is located behind the left tail light... from the top all u can see is a small white fitting with black vaccuum hoses on each side but from the bottom ( and the only way you can reach it) its a round solinoid with a 2 wire harness comming from it.
try to sniff around that area to confirm the smell of fuel.
the canister may be saturated with 16000 miles.
Apr 30, 2010 at 10:16 AM
