Fuel pressure absent at injectors... checking fuel emergency/inertial shutoff switch... switch has no voltage when plugged into harness and one wire in harness has only 6 volts when switch is unplugged... Is this wiring an input to a high impedance relay circuit that actually does the switching on/off of voltage to fuel pump or does one of these wires go directly to the fuel pump? Thanks…
Jan 16, 2009 at 9:04 PM
