Engine problem
1994 Mercury Cougar V8 Two Wheel Drive Automatic 110XXX miles
I have a 1994 Mercury Cougar XR7 w/ a V8 4.6l when I start it it stalls, after restarting it while holding down the gas alittle it will start and idle weirdly (between 500rmp to 1000rpm when cold) after it heats up it will still do the same, I changed the egr position/flow sensor and the mechanic told me that the egr was good but the the egr vacuum line may be blocked w/ crud and needs to be cleaned, heres my question, could the idle speed sensor be bad if theres irratic idling and stalling when first started and how to clean the vacuum passages for the egr?...is there a more easier way to get to the idle speed sensor and the egr pathways...thanks
Feb 18, 2008 at 11:09 AM
