1991 Mercury Cougar Speedometer
1991 MERCURY COUGAR
10,000 MILES • V8 • 2WD • AUTOMATIC
OFFONE
  • 12 POSTS
The speed part of the speedometer still works. The mileage part has stopped working. Also the trip part. Do I need to replace the complete speedometer or just the cable?
Sep 13, 2010 at 6:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Does your Cougar have the standard or the electronic instrument cluster?
Sep 13, 2010 at 10:13 PM
OFFONE
  • 12 POSTS
The instrument cluster is standard analog.
Thank You
Norman
Sep 14, 2010 at 8:07 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The speedometer and odometer/trip use the same sensor to work, it is the speed sensor mounted on the transmission. I find it hard to believe that this would be the cause here since your speedo is still working. The odometer/trip is inoperative but leaving the speedometer operative , that would point more towards a wiring issue at the back of the cluster assembly or a faulty cluster assembly itself.
Sep 14, 2010 at 5:59 PM
