Vincent answered my question about Error code E7 on the temp readout. I removed the blend door actuator and checked the motor and mix door. The mix door moves freely and If I use an outside power source the motor works. However, if I connect the blend door actuator to the heater connection, the actuator does not work. I have 4 volt reading on a meter connected to the heater connection that does not change when I activate the controls (heat, vent, defrost). Would the problem be in the blend door actuator or in the dash control module.
Thank you
Norman
Thank you
Norman
Dec 9, 2008 at 11:55 AM
