1988 Mercury Cougar
1988 MERCURY COUGAR
MARTDAWG
Noises problem
1988 Mercury Cougar 6 cyl Two Wheel Drive Automatic
were does the pcv valve vent line go on a 88 mercury cougar
Aug 19, 2008 at 4:09 PM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/forum/automotive_pictures/62217_Cougar_1.jpg
Aug 19, 2008 at 4:28 PM
MARTDAWG
i need to know on the back of the motor there is a pvc tube going from the motor to the pvc valve and there is anther conction 3 inches from the pvc valve does it go to the tranny or do you know were it goes the car runs the shitts and you can here whiseling comming from it thanks
Aug 19, 2008 at 5:26 PM
MERLIN2021
  • 17,250 POSTS
From what I see it goes to the evap emmisions canister, if you can't find it, plug the vacuum leak, it should at least run good then!
Aug 21, 2008 at 5:52 PM
