1972 Mercury Comet leaking transmission
1972 MERCURY COMET
123,000 MILES • V8 • 2WD • AUTOMATIC
REALTHING
I have replaced the front seal on a c4 trans.the trans still leaks excessively from the inspection plate,I checked for cracks there are none the torque convertor looks ok no signs of wear at the seal point. are there any other seals that can be replaced or have i missed something
Jun 14, 2009 at 9:45 PM
2CARPRO JACK
  • 11,533 POSTS
There is a front pump seal that goes around the outer part of the pump.When they leak it can be mistaken for the converter seal.Sounds like that may be it since you already did the converter seal
Jun 16, 2009 at 11:13 AM
