Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Mercury
Capri
Brakes
Drum
90 Topaz brakes
1990 MERCURY CAPRI
SQONE
MEMBER
FOLLOW
I'm having a hard time getting the rear drums off the hubs. I've tried wd 40, heat and still no luck. Any ideas?
Thanks
Sep 22, 2007 at 3:32 PM
MERLIN2021
CERTIFIED EXPERT
If backing the adjuster off doesn't do it, Remove the outter bearing and put the tire back on, pull while shaking back and forth!
Sep 22, 2007 at 4:49 PM
SQONE
MEMBER
I can get the drum/hub off the car but cannot get the hub off the drum.
Thanks
Sep 22, 2007 at 5:19 PM
MERLIN2021
CERTIFIED EXPERT
You do not want to! even if you are replaceing the drum, buy one that is put together! or you'll regret it!
Sep 22, 2007 at 6:01 PM
