1994 Mercury Capri Moisture
1994 MERCURY CAPRI
158,000 MILES • 4 CYL • 2WD • AUTOMATIC
EASPORTS
Normally the car runs great. Good power (for that size engine) doesn’t smoke, smooth running. The problem comes into play during and after a heavy downpour. At first I thought water was somehow getting into the tank because of the way it ran. It went from running on all 4’s to barely running on 2 cylinders. Once things dried up and you ran the engine hard it seemed that the water burned through the engine….everything was back up to speed.
Later on when the situation happen again, I pulled out the plugs and noticed that two were gas fouled and replaced them. Again after that I was back up to speed. Before that last heavy rain, I parked the car in my garage and still had the problem. No water hit that car so it could not be water in the fuel. I was told that the moisture on the spark plug wires was cause the problem. It makes sense but I still wanted to ask the question…..what do you think? Is this a known problem with this car? Let me know your thoughts.
May 24, 2010 at 2:55 PM
DOCFIXIT
  • 18,828 POSTS
Recomend cap, rotor and ignition wires also make sure gasket from cap to dist body in good shape
May 25, 2010 at 12:15 PM
