Motor runs continuously when key is turned on. Engine does not have to be running.
Sep 21, 2009 at 11:29 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
suspect faulty wiper motor
Sep 21, 2009 at 12:45 PM
FUTBALCOACH
MEMBER
[quote:5b28989f1d="bluelightnin6"]suspect faulty wiper motor[/quote:5b28989f1d]Replaced the motor and still have same problem. Is there a module or relay that might be the issue?
Oct 1, 2009 at 11:20 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
no relay . switch may be causing circuit to remain open or faulty wiring at the switch or motor.
Oct 1, 2009 at 2:10 PM
FUTBALCOACH
MEMBER
[quote:d156623a90="bluelightnin6"]no relay . switch may be causing circuit to remain open or faulty wiring at the switch or motor.[/quote:d156623a90]I have disconnected the switch harness with the same effect. The motor runs all of the time. When I turn the switch on the speed does change.
