1991 Mercury Capri fuel pump not getting power
1991 MERCURY CAPRI
CHEVEL71_99
Engine Mechanical problem
1991 Mercury Capri 4 cyl Front Wheel Drive Manual
i had a different engine installed. it will run as long as you feed it fuel . checked fuse under hood it's ok no power going to fuel pump as far as i can tell. what should i try next thanks for any input.
Mar 30, 2010 at 8:24 PM
Inspect and test the fuel pump relay
Mar 30, 2010 at 9:54 PM
CHEVEL71_99
changed the fuel relay and fuel pump . spark at the plugs is orange . i do have fuel at the filter going into the rail but nothing on the plugs . the guy that installed the motor changed all injecters. could it be the ecm? thanks
Mar 31, 2010 at 7:15 PM
Could be the computer injectors ground driver circuit
Apr 1, 2010 at 2:13 PM
