1991 Mercury Capri Failure to start
1991 MERCURY CAPRI
110,000 MILES • 4 CYL • 2WD • MANUAL
JACKPETTY
When engine is cold or car hasn't run for a while it won't start without spraying ether in the intake port[img]]. Engine run good once its running. And will start up good when the engine is hot. I've recently had a new fuel pump, gas tank and filter put on. Please advise my next step. Thanks[img:32551af96a]http://www.2carpros.com/forum/automotive_pictures/413700_1990_capri_3.jpg[/img:32551af96a]
Sep 25, 2009 at 12:15 PM
Test the engine coolant temperature sensor/Fp relay if okay check the fuel pressure-
Sep 25, 2009 at 1:40 PM
