whats the probability of the crank position sensor causing the car to die during driving?seems to happen mostly when slowing down. intermittently
May 3, 2010 at 3:49 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
If the check engine light is on and indicating a fault with the crank sensor then it's a good chance it's faulty. Symptoms include stalling, usually at slow speeds, or when shifting from drive to reverse . Sometimes you'll also get long cranks.
