1998 Mercedes Benz SLK230 Key will not turn in ignition
1998 MERCEDES BENZ SLK230
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
THAMMONS
THe key will not turn in ignition.
Mar 23, 2009 at 7:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Try lubricating lock cylinder with WD40 or other light oil. Other tips for this common problem may be found at the following link..
https://www.2carpros.com/first_things/why_wont_my_ignition_switch_turn.htm
Thanks for using 2CarPros.com !
Mar 23, 2009 at 7:36 PM
GFIMOTORCARS
  • 673 POSTS
You may be experiencing a failed ignition switch. A pretty common occurance on this model. Also if your steering wheel is locked solid (no movement at all) you may have a frozen steering wheel lock. This also will inhibit your key from moving in the ignition tumbler.
Mar 23, 2009 at 10:58 PM
