2002 Mercedes Benz S600 ABC Visit Workshop Message
2002 MERCEDES BENZ S600
AMAAMOUN
Suspension problem
2002 Mercedes Benz S600 V12 Two Wheel Drive Automatic 56k miles
I had the car battery changed. Since then I am getting the annoying "ABC Active Body Control Visit Work Shop"
message. I checked the ABC fluid and it seems low. I ordered a liter of CHF11s online and should get it in a day or so. Do you think this will take care of the problem? Thanks.
Jan 27, 2010 at 3:32 PM
WRENCHTOSS
  • 16 POSTS
It may but most likely you will need to find a shop with a scanner capable of clearing or resetting the codes the ABC system should reset itself after several starts if the ABC pump is putting out enough pressure..
May 21, 2013 at 7:30 PM
