the trans is a 722/3 In the valve body which valves do 3rd and 4th gear, as I was told the spools are aluminium,which maybe sticking when hot,, if you pull it down a gear and boot it ,then it won't up shift unless you stop and restart ,or are there any other ideas, maybe a broken spring ,,as the oil pan is pretty clean ie; no filings or lumps ,,
Apr 28, 2009 at 2:15 PM
