2000 Mercedes Benz S320 engine wont turn over
2000 MERCEDES BENZ S320
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAMES1916
igition comes on as normal but engine wont turn over and i cant figure out what it is
Feb 22, 2010 at 5:30 AM
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 23, 2010 at 1:51 AM
