Rear suspension too low
2003 MERCEDES BENZ E500
123,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
SENSEIZM
The car is dragging in the rear it is low to the ground. I need to know how I can obtain parts for cheap, and an honest mechanic.
Nov 27, 2019 at 4:30 AM
AL514
  • 5,464 POSTS
Hello, does this car have air suspension?
Nov 27, 2019 at 12:51 PM
AL514
  • 5,464 POSTS
Okay, I see it does, there is probably a leak in the rear of the system. These set ups can be tough to find a leak. But they are usually at the airbag that lifts the car on each side. There is a valve that balances out each side, front and rear, so if you have a leak on either side it will effect both sides. If you have the means, the lines are inside each wheel well. The wheel well comes out and the balance valve and lines are visible. They have cheap plastic lines but it's usually the bag that leaks. And most of the time the whole system shuts down if there's a leak. I'm surprised the front isn't sagging as well. Are there any warning lights on the dash board?
Nov 27, 2019 at 1:00 PM
