rpm is not stable
MERCEDES BENZ
SNOWMAN_ON
I need some technical help regarding my car (mercedes E200 model 1996)
the problem is :the rpm is not stable "going up and down between 600 and 800";my mechanic tested the car using a pc computer and said there is no any faults with my car.
:oops:
Aug 10, 2006 at 3:07 PM
2CARPRO JACK
  • 11,533 POSTS
Check for vacuum leaks, especially the rubber intake boot from air cleaner to the throttle bore. Also remove the intake boot and clean out the throttle bore around the butterfly
Nov 16, 2006 at 10:43 AM
SNOWMAN_ON
Thanks to all
the problem solved
the rpm was not stable because the ac of my car for "i dont know reason" was sending a rabid on/off signal to the computer which caused him to force the rpm up and down in simutlaneity.
Nov 30, 2006 at 8:19 AM
