engine stalls
MERCEDES BENZ
JOEY383
i have a 97 E320 with a 3.2 inline six cyl .and 180,000 miles . it stared on the highway, the abs light would flash and the car would jurk then keep running. a month the car would be idling at a light and befor i accelerated the car stalled and etc support light came on. the car started right up and ran fine. now the car started to jurk only once and ten minutes later it stalled the ETC, tration control light came on. i cranked it over ten times no start. after 15 minutes it started no lights came on and the car ran fine. the next day it did it again. i replaced the crank sensor, fuel filter ,fuel pump, fuel regulator,and all new vaccume lines. same problem.
please help..... thanks!!!!
Nov 19, 2007 at 1:39 AM
2CARPRO JACK
  • 11,533 POSTS
Need to scan the PCM for any codes it may have stored when it wouldnt start. Check all electrical connections for corrosion and tightness
Nov 20, 2007 at 11:17 AM
