Door closing assist (not locking)
MERCEDES BENZ
RNK1CARS
make: Mercedes
model: S420
year: 98
mileage: 120k
My automatic door closing assist (and trunk lid) stopped working. The door LOCKS are working fine.
I am told it is a vacumm pump but I am not sure which one of the many on this car, where it is located and if it is servicable.
Can you please give some guidance?
Feb 26, 2006 at 3:08 PM
TDILBERT
I just had mine checked-out at the MB dealer. The "elements" at the trunk and the doors tends to develop leaks. The main pump (located in the left wheel well section of the trunk) will quit trying when it detects significant vacum leakage at the elements. SOlution: Replace the two elements in the trunk lid, and the one-each at each door if needed. If you haven't burned-up the main pump, you're back in business. If you have burned it up, then it needs repacement also. BTW, how much? : the two trunk element and the main pump cost me $1500 to repair, and each other door element will run about $200 each with labor.
May 31, 2007 at 6:16 PM
