2002 Mercedes S600
2002 MERCEDES BENZ
WILDCON
The check tire pressure light keeps coming on even when the tire pressures are correct (29 fronts and 32 rears). I have had the sensors replaced but the problem persists. I check tire pressures every Sunday with a calibrated gage. Any suggestions? Perhaps disabling the tire pressure system - if so, how do you do it?
Sep 3, 2007 at 2:59 PM
GFIMOTORCARS
  • 673 POSTS
Tire pressure monitor system is very tempermental on this model. If you cannot get the monitor to reset you may have to bring it to the dealer so that they can check all sensors for correct location and so that the TPS control unit can be checked for any faults. A lot of times if the sensors are not set to the correct tire you will never be able to get the monitor to reset.
Jan 4, 2009 at 11:38 AM
