1991 Other Mercedes Benz Models Oxygen Sensor / Check Engine
1991 MERCEDES BENZ
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
CAPTAINRAINE
Two questions:
1) Where is the oxygen sensor located and how do I change it out?
2) My check engine light is on and after some very rainy days the car had trouble starting up. It would crank - but not "turn over". After pumping the gas pedal a lot it started up and ran fine. Would very much like to fix this myself!
Thanks!
Dec 19, 2007 at 6:38 PM
BLACKOP555
  • 10,386 POSTS
the o2 sensor(s) are located after each exhaust manifold before the catalytic converter, also there may be one or two after the catalytic converter.
on a warm hot day start the car up and slowly spray mist of water on various parts of the car under the hood, one bit at a time, if there is a short you will see it sparking or the car will start to die down, post back the results.
Dec 19, 2007 at 7:48 PM
