1991 Mercedes Benz 300 sl benz auto trans
1991 MERCEDES BENZ
BUZZZZ
Transmission problem
1991 Mercedes Benz V6 Two Wheel Drive Automatic 120,00 miles
well lets see how this gos ,, 91 300 sl benz ,, auto trans is rebuilt and apeers to be solid ,, no overdrive and most importly when put in 1st will more out ok but if u put the peddle down jumps out of gear (hard take off ) if your driving and deprees the peddle there is no slipping ,,
Dec 9, 2007 at 9:04 PM
ANDY22
Your overdrive problem is related to a switch in the shifter housing that locks out overdrive. Switch is less than 20 bucks, but you have to remove shifter to access it. As far as the other problems...cannot help you without more info
Dec 27, 2007 at 8:41 AM
