1983 Other Mercedes Benz Models dieseling
1983 MERCEDES BENZ
SHERRYW
Engine problem
1983 Other Mercedes Benz Models Engine Size unknown Wheel Drive Type unknown Manual 225000 miles
Recently my husband changed out all of the filters on our 240D, (oil, fuel and air), since then it diesels or continues to run when the key is turned off. I don't know how long it would diesel because he usually has to get into work and ends up having to basically popping the clutch while it is in gear to kill the engine. Any ideas on what the problem could be?
Jan 30, 2008 at 7:46 AM
DR LOOT
  • 2,311 POSTS
yes I know what your problem is, the vacuum pump is no good, that's what shuts off the engine, you can go to a European auto parts and get a vacuum Kit for about $12 and rebuild it yourself if you have the technology, but I think when your husband change the oil filter, he accidentally hit a vacuum hose that goes to the interior of the car check all of your vacuum lines and make sure they are connected they are right by the brake booster and then get back to me.
Feb 13, 2009 at 3:44 PM
