1982 Other Mercedes Benz Models COMPRESSION
1982 MERCEDES BENZ
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
DOC ROACH
My car was running just fine until I stopped for a cup of coffee. When I returned to the car it wouldn't start and hasn't run since. The mechanic said it needed a new motor. I don't see how that could be when it was running fine. He said there was no compression at all. Recently I was talking to a man that said he was a diesel mechanic. He said it might be the timing gear or chain because quite often old diesels kick back when they stop turning and that can cause a worn chain to skip. My question is would this cause the engine to have no compression at all? Thanks to anyone who might help me. Doc
May 18, 2008 at 8:27 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
it is easy to check the valve timing, but even if it missed a tooth, you will still have compressions. I would have the comps tested wet & dry, if there is no compression at all and the cam is not turning there will be a major issue with a broken crank shaft or a failed timing chain, you need to know exactly what has failed first.
Mark (mhpautos)
May 18, 2008 at 10:26 PM
