1980 Mercedes Benz Starter
1980 MERCEDES BENZ
ERSPAMER
Electrical problem
1980 Mercedes Benz V8 10000 miles
What does a starter do/
Dec 7, 2007 at 1:42 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Your starter motor is an electric motor with a Bendix drive attached, this drive is a special gear assembly that when turning, engages the teeth on the fly wheel /drive plate of your engine this in turn starts the engine turning over, with the engine "cranking over" other components are activated to initiate the starting of the engine, when the engine is running, and the key is released back to run, the starter stops turning, the drive Bendix disengages the ring gear and is not operated again until the key is turned to start.
I hope that this helps
Mark (mhpautos) :D
Dec 7, 2007 at 11:10 PM
