2000 Mercedes Benz ML430 Car Over heats normal while in idl
2000 MERCEDES BENZ ML430
87 MILES • V8 • AWD • AUTOMATIC
VLADISLAV
  • 9 POSTS
Hi my car over heats normal when in idle or driving. I have replaced the radiator fans and the engine fan clutch. It has enough antifreeze and everything else. I think it started when my MAF went out and i replaced it with an aftermarket. But that didnt work out right either because the engine would not recognize it it would turn off the check engine light off but the car would over heat and the fuel to air mixture was way off that it even cracked my CAT converter. after i drove the car for a little bit with that MAF sensor the car would overheat and shut off. Then i bought a factory MAF and put it in the car ran great but the engine does not stay at normal temperature it just goes up and down. If i park somewhere and stay at idle for a minute the engine temp rises when i start driving it goes down and i cannot figure out what the problem is.
Jan 9, 2009 at 11:35 PM
JAMES W.
  • 2,394 POSTS
Do your radiator fans come on when the overheat occurs? Is the engine thermostat sticking?
Jan 9, 2009 at 11:59 PM
VLADISLAV
  • 9 POSTS
no the fans do not come on when it over heats.
Jan 11, 2009 at 2:03 PM
JAMES W.
  • 2,394 POSTS
In the fuse block under the hood on the driver's side, check 30a fuse #44. This fuse feeds the fan relay for the cooling fans. If fuse is good, check the fan relay in the same location. Next, check 25a fuse #41 for the circulation pump and the relay next to it. Let me know what you find.
Jan 11, 2009 at 8:39 PM
2000 Mercedes-Benz ML430 over heating problem,i have changed the fan and pulley
Jun 20, 2012 at 3:22 PM
start with a leak down test to confirm a head gasket
check the thermostat for proper operation.
the radiator could also be clogged as well.
do not drive this until you have it repaired as you may damage the motor
Jun 20, 2012 at 4:56 PM
