There was a 132k mile service and then the next one would be 144k miles. This is for the 144k mile service.
Inspect
Battery
Check condition of main battery & auxiliary battery (if applicable) using "Midtronics MCE 717" Tester. Check and correct fluid level of battery (if applicable).
Brake Fluid
Brakes and Traction Control
Check condition of front/rear brake pads for lining thickness. Check condition/thickness of brake discs front/rear. Inspect lines and hoses for signs of chafing, leakage or damage.
Cooling System
Check engine cooling system, antifreeze and corrosion protection. Check lines and hoses for signs of chafing or leakage.
Drive Belt
Check condition of poly-V-belt.
Fluids
Leakage - Major components. (Underside of vehicle and engine compartment) Check for chafe marks, line routing, damaged components.
Hood
Check catch, safety catch, and hinges on engine hood for proper operation. Lubricate if necessary.
Lighting and Horns
Horn, headlamp flasher, hazard flasher, turn signals, warning/indicator, illumination and interior lighting, exterior lighting, trunk/cargo area, including headlamps.
Parking Brake System
Check parking brake. (function test only)
Power Steering Fluid
Seat Belt Systems
Check seat belts for damage and proper function.
Steering
Check condition of steering's mechanical components.
Suspension
Check condition of front & rear axle ball joints.
Washer Fluid
Wiper and Washer Systems
Windshield wipers/washer system. Headlamp cleaning system and rear window wiper/washer system if applicable.
Inspect/Adjust
Headlamp
Not for Xenon headlamps
Inspect headlamp aiming, adjust if necessary
Lubricate
Throttle Cable/Linkage
Lubricate points on throttle control, check operation and condition.
Replace
Cabin Air Filter
Replace dust filter.
Engine Oil
Oil Filter, Engine
Wiper Blade
Replace windshield wiper rubber insert(s). Check condition of rear wiper blade.
Reset
Service Reminder Indicators
Rotate
Tires
Inspect, rotate if necessary. Except vehicles with different sizes front/rear.
Oct 12, 2010 at 11:55 PM
