I get a lot of noise after I press on the brake pedal? sometimes, I hear the same noise when I turn on the car. It sounds like air leak??
Dec 31, 2008 at 12:30 PM
GFIMOTORCARS
CERTIFIED EXPERT
You may have a leak in your brake booster. Have a friend turn on the vehilce and press the brakes while you listen at the booster. You should be able to here the leak well. This is a common repair and usually requires replacement of the booster in this model.
