How do you change the oil on 2005 Mercedes-Benz E320? where the pliug
Jul 28, 2009 at 10:53 AM
CERTIFIED EXPERT
The drain plug is located on the oil pan. I believe it faces the rear of the car. Also, some of these have an internal oil filter cartridge. Have you located that?
Jul 29, 2009 at 12:04 AM
CAR WIZARD
MEMBER
you need to remove the lower panel bolts which are a 8mm socket size. drop the panel down and the drain plug is 13mm.the filter is is a plastic housing on top of engine be sure to replace all the oil rings on the filter carrier.good luck.
