air conditioning works just fine unless it rains?
1995 MERCEDES BENZ E300D
235,000 MILES • 6 CYL • 2WD • AUTOMATIC
DONCBOX
The air conditioning works just fine unless it rains or go through a car wash then it will only blow hot air. After about a day of drying out it works just fine again. During this period the windows will fog up really bad.
May 5, 2010 at 12:13 AM
Sounds like you are low on Freon. It is not uncommon for when you are in high humidity situations that the A/C is not able to keep up. Basically, the A/C running is what controls moisture so when there is more than it can handle the A/C stops performing well.
I would suggest we start with checking the Freon levels because that will tell us if it is low of the compressor is failing.
There is a chance we have a sensor issue but the pressures would be correct at that point, so we need to start with the pressures. Plus, on this older vehicle, I doubt there is a humidity sensor in the system.
Please see the attached info below for a chart on pressures and possible causes.
Let us know what you find. Thanks
Dec 15, 2021 at 1:56 PM
