[quote:46b89e4df0="gfimotorcars"]If its going away after 20 mins then its more than likely not a voltage regulator, You may have a slight amperage draw from a component not turning fully off and drawing down your battery. Does the vehicle ever have a long crank before it starts? This warning in this case is telling you your battery voltage is low and will not turn off until the alternator charges the battery past the warning level. If this is an amperage draw it will eventually kill your battery when the car sits a couple days or even over night. If you have noticed the vehicle cranking for a longer time when you start it up in the morning then this is probably the case.[/quote:46b89e4df0]
No there is no problem when starting it fires up straight away after a short normal crank, the warning goes off after driving for 20 Miles. So it looks like it could well be loss of amperage and getting recharged via alternator, How can i check what is causing the amperage loss? do you think i should get a trickle charger to keep battery topped up and what are the problems in charging the battery while it is still connected. Saying that the car is used daily so really it shouldn't need charging.
Thanks.
Mar 23, 2009 at 6:01 AM
