1999 Mercedes Benz CLK320 TRANSMISSION
1999 MERCEDES BENZ CLK320
81,200 MILES • 6 CYL • 2WD • AUTOMATIC
DRDRE
i live in Antigua in the caribbean and i am having a problem with my transmission .
when you select from park to drive the vehicles transmission would not shift ,try to do it manualy and it just stays in one gear it seams to me as if the transmission is stuck in 3 rd gear .
it reverses well but just wont shift in forward gears.
could you please give me some advice it will be greatly appreciated
Dec 16, 2007 at 5:23 PM
GFIMOTORCARS
  • 673 POSTS
Your transmission valve body may be malfunctioning. When this component fails often times you will you will be locked out of gears. This is an issue that will definately require a good trans shop or a dealer to remedy.
Feb 15, 2009 at 10:19 PM
