1998 Mercedes Benz CLK320 Heater blower
1998 MERCEDES BENZ CLK320
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
EMURCIA
My heater blower was working once in a while and finally stopped working. Fuse is OK. Is there a relay that controls this, if yes where is it located and is there a way to test it? Secondly were is the heater blower and what is the procedure for removal and replacement. Thank you, EMurcia
Feb 19, 2008 at 8:13 PM
GFIMOTORCARS
  • 673 POSTS
If the blower motor was only working on certain speeds then stop working then you have a failed blower motor regulator. If the blower motor just canme on every once in a while on no particular speed then you have a burned blower motor. The blower motor and regulator are located under the passanger side dash. Remove black cover under passanger side dash. The blower motor and regulator are immediatley behind this panel.
Jan 5, 2009 at 10:47 PM
