1999 Mercedes Benz CLK230 Error Code 170
1999 MERCEDES BENZ CLK230
STELLADOW
Computer problem
1999 Mercedes Benz CLK230 V8 Automatic 82000 miles
What the error code 170 mean and is it serious?
May 11, 2009 at 4:38 PM
BMRFIXIT
  • 19,053 POSTS
If its code p0170 its an indication of fuel trim issue check for an air leak vacuum leaks, injectors ,engine wear
if engine running OK for you and no noticeable problem you should be all OK to drive until you can have it checked
good luck
May 11, 2009 at 9:28 PM
PRENAUD104
I recieved that error code p0170 after I lost my oil cap any vaccum leak in the engine will give u that code check ur oil fill cap.
Mar 15, 2010 at 1:46 AM
