2001 Mercedes Benz C320 warning light
2001 MERCEDES BENZ C320
73,000 MILES • 6 CYL • AWD • AUTOMATIC
RENEE521
Hi a yellow triangle light in dashboard flashes? Also at one point it stayed on,what does this mean?
Feb 11, 2009 at 7:17 AM
GFIMOTORCARS
  • 673 POSTS
The yellow triangle means your traction control is slipping. It is a warning basically that you may be loosing traction. When the triangle stays on this could happen when the vehicle goes into a slide. Also if you turn off your ESP function the yellow triangle will come on and stay on in the dash until ESP is turned back on.
Feb 28, 2009 at 11:45 AM
