TURN SIGNALS
1995 MERCEDES BENZ C280
103,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLEVERAC280
my turn signals sometimes don't come on when i move the lever! i changed the fuses and still have the same erratic on/off situation. the flashing signal on the dash board showing which direction I'm turning won't illuminate! when i got home and restarted the car, they were working! do i have a loose connection somewhere that i need to know about?
Apr 29, 2009 at 10:31 PM
More than likely this is a turn signal switch issue. So, here is a video on a similar vehicle that will help with this:
https://youtu.be/pLDjYWv-ApQ
https://www.2carpros.com/articles/turn-signal-switch-replacement
I am attaching some additional information about this switch below which will help with this.
However, the way to confirm this is to access the switch and check the voltage coming from the switch
Please find the wiring diagram attached as well so let's start with this info and we can go from there.
Thanks
May 22, 2022 at 11:09 AM
