Hello .. thanks for the donation .. much appreciated
Remove the front wheels
2Detach left front brake pad contact sensor connector (S10/1x1)
3.1Remove bolts (31c) and detach floating brake caliper (31a) upwards Tie floating brake caliper (31a) to body.
Check dust boots (47) on floating brake caliper (31a) for damage.
3.2Drive out retaining pins using a punch and remove retaining plates
4Remove brake pads (31g) .. Install in the reverse order
Hope this helps
Apr 10, 2010 at 2:28 AM
