1997 Mercedes Benz C230 Crank position sensor
1997 MERCEDES BENZ C230
136,000 MILES • 4 CYL • 2WD • AUTOMATIC
MS_MADS
Hello, I need to change the crank position sensor on my C230, Could you please tell where it is located and do I need any extra ordinary tools to get to it?
Jan 29, 2008 at 7:59 PM
STEVEW84
  • 673 POSTS
Its on the back of the engine on the drivers side.
Mar 24, 2008 at 9:28 PM
MS_MADS
Hello, Thanks for your response and I was able to find it and replaced it.
My car still does not seem to start. I have changed the crank position sensor, mass air flow sensor, fuel pump, fuel filter, ignition coils.
when i crank it, it appears to start for around 2 seconds and then dies.
Any suggestions would be of big help.
Thanks
Mar 25, 2008 at 7:23 AM
WESTCOAST619
  • 16 POSTS
When you turn the key, your vehicle will try to crank for a few seconds untill the engine reaches above 400rpm then it will disengage the starter. What it seems is that your engine cranks but does not start. Even though you replaced your fuel pump, I would still check fuel pressure. It sounds like a fuel or spark issue. Also check your fuses for your fuel injectors and ignition coil packs. It may get expensive to replace random parts. It might just be cheaper to get it daignosed at a shop/dealership and repair it yours self. Hope this helps
May 6, 2008 at 9:06 PM
