1999 Mercedes Benz A160 Tripometer Display
1999 MERCEDES BENZ A160
ISOVITIS
  • 5 POSTS
Electrical problem
1999 Mercedes Benz A160 4 cyl Two Wheel Drive Automatic
The tripometer display does not light up. The digits are not visible.
What is the problem? What should i check?
Can I repair it my self?
P.S
On photo the digits are visible. That is because of the cameras flash light.
[img:eff1ff7990]http://www.2carpros.com/forum/automotive_pictures/490511_DSC00343_2.jpg[/img:eff1ff7990]
Feb 26, 2010 at 5:49 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated Start by checking the dimmer switch for the interior lights is functioning correctly ! Hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_1010.png
Feb 26, 2010 at 8:43 PM
ISOVITIS
  • 5 POSTS
I did try that and its works with all the other lights but not for display.
I also checked all the fuses that are related with the "instrument cluster".
Feb 27, 2010 at 1:47 AM
DAVE H
  • 13,384 POSTS
you will need to replace the LCD i'm afraid ..this is a common fault on this type of display module. Liquid crystal display (LCD), location/task/function - GF54.30-P-3015A MODEL 129, 140 as of 1.6.96, 163, 168, 170, 202 as of 1.8.96, 208, 210 as of 1.6.96, 215,220 Task The liquid crystal displays (LCDs) can display numbers, letters and other symbols. They are therefore used as the output devices of electronic systems. They are increasingly used as a replacement for the conventional analog indicating instruments and indicator lamps. Operating principle The operating principle of the liquid crystal display is explained using a seven-segment display as an example (see illustration). A spacer frame (d) which surrounds a thin layer of liquid crystal (e) is sandwiched between the glass plates (a) and (f). Transparent electrodes (segments) are attached to glass plate (a) in the shape of the desired characters. Fig. 68: Identifying Liquid Crystal Display (LCD) Courtesy of MERCEDES-BENZ OF NORTH AMERICA.
https://www.2carpros.com/forum/automotive_pictures/266999_merc_7.jpg
The transparent counter-electrode (h) is on glass plate (f). If a voltage is applied between the contact (g) of the counter-electrode (h) and one or more contacts (b) of the segmented electrodes (c), the optical properties of the liquid crystal between the counter-electrode (h) and the energized electrodes (c) change. If the LCD is viewed in the direction of the arrow, the energized electrodes (c) appear dark and are thus visible. By actuating the appropriate electrodes (c) it is possible to display any number. The liquid crystal display also has 2 polarization filters (i). These types of display have a better contrast and require a lower supply voltage (approx. 1.5 - 5 V). Other characters can also be displayed if the appropriate electrode layout or shape is selected. Strip-type electrodes are usually used in the multifunction display (A1 p13). Here strip-type electrodes are attached to both of the glass plates (a) and (f). The strips on glass plate (a) are arranged vertically to the strips on glass plate (f). This arrangement allows individual dots (pixels) to be actuated. If different dots are actuated repeatedly in sequence at a sufficiently high speed, it is possible to produce almost any "image".
Mar 3, 2010 at 5:19 AM
ISOVITIS
  • 5 POSTS
Before I tried what you told me ,I gave a "tap" on the dashboard and the lights came back on.
Since then Its been fine.
Thanks
Nov 4, 2010 at 4:04 AM
DAVE H
  • 13,384 POSTS
Thanks for letting us know your final fix ! Happy motoring .. please use our forum agian in the future if needed and spread the word to family and friends.
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_1202.png
Nov 4, 2010 at 4:16 AM
