transmission won't upshift sometimes will operate normallywhen cold then once warm will stay in lower gears
Jun 27, 2009 at 2:18 PM
DR LOOT
CERTIFIED EXPERT
You failed to mention if you check the transmission fluid when the transmission is cold the transmission fluid is sufficient when the transmission warms up the oil expands which makes it starve for oil pressure
