1986 Mercedes Benz 560sec removal of timing cover
1986 MERCEDES BENZ 560SEC
10,900 MILES • V8 • 2WD • AUTOMATIC
SWIGGYBENZ
I can't get crankshaft dampener bolt loose, is it reverse thread ?
Jan 2, 2009 at 5:29 PM
CHARTAN
  • 6 POSTS
I don't think they are reverse thread. How are you trying to take the bolt off? If you are using an impact, the timing belt will absorb the impact of the impact wrench. You need to hold the flywheel and try a breaker bar. Hope this helps!
Jan 2, 2009 at 5:43 PM
SWIGGYBENZ
thanks for your response, have tried both methods impact &breaker bar, I broke 2 extentions trying to remove bolt with half inch drive . now what? I am very mechanically inclined just first time on this type of problem....
Jan 2, 2009 at 8:49 PM
CHARTAN
  • 6 POSTS
Some of the imports use thread locker and need heat to be broken loose.
Jan 3, 2009 at 8:02 AM
