1993 Mercedes Benz 500sl Where do i pour the power steering
1993 MERCEDES BENZ 500SL
DEVILDOGDAD
Steering problem
1993 Mercedes Benz 500sl Two Wheel Drive Automatic
Can't find where to pour power steering fluid. I checked it with the dipstick and it's dry. Do I pour it into where the dipstick is?
Mar 30, 2009 at 4:17 PM
BCELANI
The power steering fluid reservoir is under the hood at the front of the engine and easily accessible. The cast aluminum reservoir has a large black knurled plastic nut that holds the top on the reservoir. Turn the nut counterclockwise and remove it, then take the top off the reservoir. The reservoir has a fluid filter in the bottom that can be removed and replaced using a pair of needle nose pliers to extract it. Fluid retains water so its a good idea to remove the fluid every couple of years with a turkey baster and replenish it up to the cold mark on the center post. The top has a rubber o-ring that should be replaced as well to make sure the cavity is sealed
Apr 21, 2009 at 11:07 PM
