1976 Mercedes Benz 450sl Car is mixing gas with oil
1976 MERCEDES BENZ 450SL
CORN266
Engine Mechanical problem
Because the car is mixing gas with oil the engine is not working and i'm not a very car technical person. Could anyone please explain how to fix this problem and about how much it would cost?[img:043a17ac31]http://www.2carpros.com/forum/automotive_pictures/549097_D6D62662A1F6167F86E94D21E36C4333B74AD0D5C26FF42C8732AB9FEAB4569B_2.jpg[/img:043a17ac31]
Jul 11, 2010 at 7:50 PM
TODDPERRY
Depending on how long this has been going on, you may have already spun the bearings due to poor lubrication.. A total rebuild would be recommended if the mileage is rather high, 1ooK plus miles. Cost could range from $ 4,000-$5,000.
Jul 20, 2010 at 3:30 PM
SCOTTINSOCAL
  • 22 POSTS
Do you have oil getting into your fuel (lots of blue smoke out the tailpipe)?
Or do you have fuel getting into your oil (oil level goes up, the oil gets thin, and you spin bearing and the pistons chew out the sides of the cylinders)? Either problem is more than a "not very car technical person" would be able to fix, but knowing which would help you when you take it in to have someone fix it.
I do have to break it to you that a quality engine rebuild on the M117.985 engine - the one in your car - isn't $4-5K. It's more like $8-10K.
Dec 10, 2010 at 8:52 PM
