1982 Mercedes Benz 380sl performance w107.45
1982 MERCEDES BENZ 380SL
JFERRARASR
Engine Performance problem
1982 Mercedes Benz 380sl V8 Two Wheel Drive 88000 miles
If I start the car cold, it runs fine all day, till I turn it off, if I leave it off for at lest 15min or more. It loads up and runs rough till engine gets cold again!!! I go from about 18mpg. to 10mpg. Could it be the fule pressure vale, located at tank?
May 27, 2009 at 4:18 PM
2CARPRO JACK
  • 11,533 POSTS
I have forwarded your question to our M/B tech. He will be with you shortly, thank you for your patience
May 29, 2009 at 8:20 AM
2CARPRO JACK
  • 11,533 POSTS
It is possible.You will need to install a manual fuel pressure gauge to see where it is at.It could be a sticky injector or coolant sensor as well.Try pulling the plugs to see if any one is darker than the others
Jun 12, 2009 at 12:01 PM
GFIMOTORCARS
  • 673 POSTS
Jack is on the right track. Definately check your plug condition first. If they are black you may have a leaky injector. This will cause excess fuel to be in the combustion chamber especially when hot, causing a rough running condition after the vehicle has been warmed up and parked. This model is known to have issues with leaky injectors as the car ages
Jun 12, 2009 at 1:24 PM
